Ben Jammin
Well the 2010 SS that I bought is home. It has some good and some bad.
It had a dead battery upon arrival, so I took it out and charged it. Car starts and runs decent.
The good,: low miles 60000 on the odometer ;D ;D ;D. Has the GM stage 1 kit and aluminum charge piping already installed so it has a little more HP and Tq than stock. The body and subframe look good no major damage that I can find. Should have a lot of re-sellable parts. Has the Multi Function Display which looks really cool and gives a ton of Data parameters.
The Bad: It did take a whack into something, maybe a spin out into a curb. The rear live axle is slightly tweaked and there is a smack mark from where the driver brake caliper contacted the frame. The driver rear wheel alignments appears to be off a couple degrees.
No G85 option! Grrrrr , I should have done my research better, but apparently I have one of the only 2010 SS cars to not have the LSD.
The worse: There is something definitely wrong with the driver front driveline . Car drives, but upon each revolution of the driver front wheel there is a horrible grinding sound. Car goes about 4 feet quietly and then grinds, repeat for each 4 feet driven. I havnt investigated yet, but might be a damaged drive axle, damaged wheel bearing, or in the transmission. Service ESC, Service ABS, and Service Traction Control on the dash. Due to a broken ABS sensor wiring harness.
This may be a fix up, flip and sell, and then grab a different car, not sure yet. Thinking about it now.....
