baustin
Overall a neat day at autocross yesterday, was on the "Little Rock" track outside the main Rockingham Speedway.
From folks that do autocross a lot, there wasn't a lot of grip on the track. Surprisingly the banking wasn't too weird for me. Unfortunately I did end up spinning out on my first run... again... across the finish line. At least this time I didn't hit the cones at the finish, only after the finish. Whether that 1st run should be a DNF for taking out 3+ cones after the finish didn't matter since my 4th run was only .002 slower. Ended up that my 1st run was my fastest, when I tried to push harder on the 5th run I ended up sliding on the inner loop and being .2 slower, I figure I lost at least .5 from that slide. I'm not good enough yet to know if my tires really have any more capability but I didn't really feel like I had any more grip in the later runs or which direction I should adjust my shocks. I'm sure a lot of it has to do with smoothness on the inputs which isn't my strong suit so far, hence my spins at the finish. I'd rather learn my car better before replacing the tires though I will be replacing them at some point this year since my initial alignment badly wore the front tires (currently on the rear). I'll need to look into what type of tires I want but am kind of surprised at the current pricing, the tires I bought in 2019 are now 40% more expensive, they used to be on the cheap end.
Run #1
Run #2
--forgot to record this one, had an instructor riding along--
Run #3
Run #4
Run #5
During tech inspection, they noticed a slight clunk when pushing/pulling on the front wheels. They still let me run but where wondering if it was the bearings. I took a closer look back home and it seems that it's the heim joint sphere inside of the bushing. The portion I'm pointing at in the picuter. With a finger tip on the sphere, you can feel it move relative to the eye bolt portion (not sure of the correct names here). The bushing isn't moving, just the sphere. It's not a slip of the upright bolt within the sphere, and it's not the threaded end of the heim joint to the control arm. I don't see any correlation between the distance threaded out and this clunk, the lock nut has remained solidly tight and any wear on the bushing should be independent of the threaded length, after 2 autocross events with 2 full spins I feel comfortable with the engaged length on a car this light. I feel a very similar movement on the driver side, maybe just slightly less clunk sound though. I don't feel any clunk from the lower heim joint, either driver or passenger. You can feel the clunk through the upper control arm when pushing/pulling on the wheels (makes sense with it all being bolted together), and nothing on the lower control arm. Not sure if I should order some replacements for these upper heim joints or if this is typical for heim joints. Maybe others can confirm if pushing on the top of the wheel produces a slight clunk/movement from within the upper heim joint?
My upper heim joints can swap sides (top passenger <-> top driver and bottom passenger <-> bottom driver) but my lower heim joints are left hand thread instead of right hand, so I can't swap top to bottom. I probably should just buy 2 of the right hand thread type to have ready to swap in.
Run #1
Run #2
Run #3
Run #4
Run #5
