Brembo Brakes
George
I run Wilwoods calipers because of the weight they weigh less that 4# with pads per caliper and use a vacuum regulator to adjust the amount power power assist for better feel. I have not heard of any one complaining about the brakes that are supplied unless on some front to rear brake bias. for that us just install an adjustable restrictor to the rear brake line.
If you run the Brembos in front you will need to match an properly sized caliper for the rear.
Brad
IDRVSLO
Yeah, I can imagine with the weight stock calipers will work out just fine. Guess I should sell mind and recoup some more funds.
IDRVSLO
Adam also recommends staying with the supplied brakes or finding something to go lighter with! Good to know! Thanks all.
