Build Guide Part 23 - Front Suspension
Discussion in 'Instructional Build Videos' started by Adam, Oct 8, 2017.
  1. Adam
    In Part 23 we install the front control arms, coilovers, knuckles and hubs.
  2. David
    David Well-Known Member
    Awesome I can't wait till a near future when I will be on that stage :(
  3. TheNuker
    TheNuker Well-Known Member
    No wonder when I turn right it goes left I put it all on backwards!!!!!
    Jkjkjk
    Nuker
    Adam likes this.
  4. BAR-AIR
    BAR-AIR Well-Known Member
    Yeah..... really the front of the donor car goes in the back?
    Adam likes this.
  5. Briann1177
    Briann1177 Well-Known Member
    Will the new videos eventually be uploaded to Google drive?
  6. Adam
    Before I left the shop yesterday I started encoding the version for Google drive. It is uploaded to the shared folder now: DF Goblin Build Guide on Google Drive
  7. Matt TT
    Matt TT Member
    Anyone have any advice for getting the wheel hubs into the uprights? I can't seem to fit them with the ABS plug receiver on the back side and I destroyed it to the point it wont even turn anymore when I tried to get it to sit flush. Thanks!
  8. ctuinstra
    ctuinstra Well-Known Member
    I might have helped to heat the spindle in the oven to 200-250 and freeze the hubs overnight in the freezer. Might have dropped right in. Also clean the heck out of the corrosion on the inside. Mine was corroded and pitted so bad.
  9. Errorunknown
    Errorunknown Active Member
    I had to grind down the plastic ABS connector, once I did that had no problem fitting in. This is with 2008 SS hubs
  10. RichN
    RichN Well-Known Member
    I removed the ABS plug on mine and replaced with trailer caps. Had to grind down the lip a little to fit, see my build log page 2 post 34
  11. Matt TT
    Matt TT Member
    Thanks all! I'll give grinding them down a try!
  12. Matt TT
    Matt TT Member
    Did you have to grind the metal underneath the plastic at all, or just the connector for the ABS?
Share This Page
