Sluggonaut
I was wondering how everyone approached their build strategy.
I was considering assembling everything with my currently running donor parts and making any frame changes I thought I needed (i.e. trick tabs for side panel and cargo carrier) before taking it all apart for the next step. The next step would be sending the frame/parts off for powder coating and opening the engine up for timing chain/bolt update, water pump, clutch, and possibly head gasket.
I want the initial build to be with the donor in its current running condition to make issue troubleshooting easier, knowing that assembly after powder coating would be quicker the second time through and make it easier to identify any issues I might cause with the engine work.
I see a lot of build logs where powder coat happens then the build occurs and was curious if it's worth going the build/powder/reassemble route.
My only concern with building it and then disassembling for powder coat is the coolant hoses. Is it easy to remove the hoses or do you just do the first start with no cooling system and not let it run very long?
I'm still a couple of months out but I'm a planner, so just trying to get my plan straight now.
Thanks in advance for your input.
