BAR-AIR
Brian,
Cut the tunnel. Your either going to touch up the powder coating where you cut the tunnel (where you are controlling the scratches) or your going to be touching up the scratches on the walls and frame the first time you try to remove the tunnel. If your concerned about the cut two blocks of wood clamped on either side of the cut, tape the tunnel first and a new blade really only touched up the raw ends. Sectioned mine in to three pieces due to the emergency brake handle.
