The radiator hose routing is pretty simple (I used marine hoses just for simplicity). PASSENGERS SIDE
DRIVERS SIDE hose goes directly to thermostat housing.
Other end of drivers side hose at thermostat housing. 3/4” hose coming off thermostat housing goes directly to the bottom of the reservoir.
Above the passengers side radiator hose (look closely you can make out the yellow stripe on the hose) you can see the routing for the hose going to the top of the reservoir.
Not a great picture but it you look closely at the end of the supercharger’s case (just before the rubber coupler) you can make out two outlets first one has a rubber plug on it and the second one has the hose that eventually gets reduced in size (at least that is what I did takes up less space in the center channel), that runs to the front brake booster.
