Whidbey Goblin
I’m not sure what this little sensor is next to the evap. Do I need it?
Thank you, all you guys are great! I really appreciate the help.The EVAP that is in your hand, no, you don’t need to keep it. The other one for the boost solenoid, yes, keep it.
Do I route this line to the boost solenoid?The EVAP that is in your hand, no, you don’t need to keep it. The other one for the boost solenoid, yes, keep it.
Also is there supposed to be another line going to the lower portion of that sensor?Do I route this line to the boost solenoid?
YepDo I route this line to the boost solenoid?
No. It’s atmosphere. Should have a “filter” over it.Also is there supposed to be another line going to the lower portion of that sensor?
Got it, thank you. Do you know what that filter is called? Or should I just get one of those cheap little plastic filters in the short piece a vacuum line?No. It’s atmosphere. Should have a “filter” over it.
You are a wizard, thank you!Any piece of foam should work. It’s mostly to keep debris out of the solenoid so it won’t stick.
