Nice work!E-Brake/Parking Brake - Unfortunately I did not save my E-Brake hardware so I had to build it from scratch. Did not see much info on here so I took a lot of pictures of what I did. The E-Brake handle is readily available (Ebay) as are the cables (Rock Auto). The rest I had to cobble together. As we say in the Navy "Works great, failsafe & it drains to the bilge".
Looks familiar...Needed to add some USB charging ports. Found this nice piece that has an On/Off switch, a DC Volt readout, two USB charging Ports & a cigarette lighter socket (for Camera or Radar detector). Pretty easy upgrade & looks nice. https://www.amazon.com/gp/product/B0741C4F78/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
I like how you mounted yours, I’ll probably copy !Looks familiar...
Here is a quick crude dimensioned drawing of my pattern to get you started.I like how you mounted yours, I’ll probably copy !
I think your setup looks way better than the stock tubes..E-Brake/Parking Brake - Unfortunately I did not save my E-Brake hardware so I had to build it from scratch. Did not see much info on here so I took a lot of pictures of what I did. The E-Brake handle is readily available (Ebay) as are the cables (Rock Auto). The rest I had to cobble together. As we say in the Navy "Works fine, failsafe & drains to the bilge".
Nice job FrankE-Brake/Parking Brake - Unfortunately I did not save my E-Brake hardware so I had to build it from scratch. Did not see much info on here so I took a lot of pictures of what I did. The E-Brake handle is readily available (Ebay) as are the cables (Rock Auto). The rest I had to cobble together. As we say in the Navy "Works fine, failsafe & drains to the bilge".
I just picked up a new Plasma Cutter today so that will work great for cutting your design out.Here is a quick crude dimensioned drawing of my pattern to get you started.
Are you saying the Statue of Liberty is ugly? Gaspp. LOLThe copper tubes look great, but forgive me if this is a dumb question. Won't they oxidize and get ugly?
Plasma Cutters are FUN I used one to cut up the shell of my donor.I just picked up a new Plasma Cutter today so that will work great for cutting your design out.
Did not see that. Another good location for that panel. Looks good !Looks familiar...
As far as I know both are required. There is an exception But I'm not sure how to get it. Probably can drive without it. You could always say "must have fallen off"Is it a requirement to run both rear and front plates?
