AleX1/9
Setup is now on the car! I ended up using the thrust washers right against the machined strut tower pieces and the clearance was close on the mounting hardware, but it worked nicely.
I used camber bolts on both upper and lower bolt holes and got a LOT of negative camber available, this picture has them set with as much camber as possible.
