Do you happen to have a picture of this on your engine?
I didnt end up doing it. The ECU doesn't squawk if the dummy light isn't plugged in. I'm not running the Cobalt gauge cluster, so theres really no need for it anyway. Just running the oil pressure gauges sensorDo you happen to have a picture of this on your engine?
How’s the passanger compartment looking?Also started prettying up the engine bay
No real progress yet. Been mulling over ideas. Now thag the CNC is back up and going properly I can start work on fiberglass. Side pods first because I have no heat exchanger loop currently. Then dash.How’s the passanger compartment looking?
I had the same thought. Will be testing todayCurious how close that comes to the top of your legs under the wheel and on the passenger sides? From the angle of the photo it looks close, but could just be an optical illusion.
Yep, that's out. Thanks for mentioning thoughOne of the a/c compressor bolts holds the pan in, just fyi.
