If the oil was changed regularly, I would think it would work. Certainly well tested, and no porous block.
Thank you for your input. I've decided against it. $1k for a rusty SS was tempting though lolAt 250k miles, I would expect everything to be worn out of spec and need rebuilt. Even with very liberal oil change intervals, it’s still very worn. And it’s doubtful that that it’s been changed like it should as it got more worn.
You might be able to reassemble it and putt around, but no way I would put good parts in It without a full rebuild.
Suspicion confirmed. ZZP recommends the LNF head gasket for the LAP because of the matching bore.Looking at RockAuto, it seems that the 2.2L LAP uses the same head and headgasket as the 2.4L LE5. That is what was on there from the factory, and what I put back on. But...
The LAP has the same bore (86mm) as the LNF and is from the same year range. Would the LNF gasket make more sense to use on the LAP instead of the LE5 gasket? Especially in a boosted scenario. I only ask because when I looked into ordering a custom thicker gasket from Cometic, they list the LE5 gasket with a 90mm bore, the LNF with an 88mm bore, and the L61 (a true 2.2L) with an 87mm bore. The L61 won't work because the gasket doesn't have the little circles on it for the VVT actuators (if I understand it correctly). Seems like it would make sense to match bore as closely as possible, but I guess combustion chamber size could be different?
LNF Head Gasket
That is what it may do. Shouldn't be a problem. It will return to normal as coolant is sucked back in.I plan on using a vacuum bleeder for the coolant once its put back together. Is there any concern with the coolant hose going thru the frame collapsing when vacuum is pulled?
skunkworks?Guy said the valve guides were all outta whack. You could wiggle the valves around and they'd move quite a bit. Makes sense why they wouldn't be sealing properly. To be clear I paid an ecotec shop (not ZZP) to do these. Frustrating, but at least I know it'll be done right this time
