Finally for some long overdue updates, hitting some of the high points. I got through the refreshing process of the engine. I replaced all timing components including the new tensioner, water pump, all gaskets that were removed, spark plugs etc.
The engine and transmission were sprayed with Rustoleum high temp (2000F) primer then Rustoleum Ultra high temp (1200F) silver. It came out a bit more flashy than I was anticipating but happy enough with the end result.
I will address the valve cover sometime later.
I cleaned and walnut blasted the intake runners and valves, it was very time consuming and tedious but they're as clean as they've been since the donor rolled off the dealer lot in 2010. Before and after images below. Note, the valves are open in the first image, they were closed before cleaning. I used a combination of plastic and brass picks of various shapes, CRC Intake Valve and Turbo cleaner, compressed air and shop towels.
With the help of a really good friend and welder I made numerous minor additions or modifications to the frame. I might have missed some but this is most of them:
Custom welded M6 tabs for side panels (overkill but didn't want to add more holes into frame)
Cut tunnel cover into 3 pieces
Welded M4 SS square nuts in tunnel for tunnel cover
Welded M6 SS nuts for hand brake
2 welded posts for M8 bolts through shifter plate for a very solid shifter
I will also be using one of the K Tuned aluminum shifter assemblies
Cut and welded 'ramped' feature for tucking shifter cables under hand brake
M4 rivnuts for floor pans and firewall
M5 rivnuts for all hard brake line hold downs
M5 rivnuts for passenger kick plate
Side panel mocked up with all of the new holes for the welded tabs.
Frame sanded and cleaned and ready for powder coat.
Frame picked up from the powder coater. I went with Kingsport Gray (Prismatic) for the frame, control arms and tunnel cover pieces. The picture doesn't quite do the color justice. Not pictured is the fuel tank, kick plate, front bulkhead panel and a few other small pieces that were coated in a flat black.
This was a relieving sight.
I have begun the actual build/assembly process but will leave that for another post.
