In my case, the nut behind the wheel is 6'3" 215#Do you guys happen to know the nut size for the steering wheel?
Thanks good choice on the extended trackIn my case, the nut behind the wheel is 6'3" 215#
The nut you're after is a short M14-1.5 nylock
Picked these up tonight thanks.I think a lot of us are using the Duralast Gold DG956 brake bads all the way around. Lonny was kind enough to demonstrate on mine that they stop very well.
Hey Rich I ended up finding a swivel Bush’s g that with a c-clip from ACE hardware that will work. I assume the lines matter in the way they are connected to the transmission and shifter I cannot seem to find a guide for both explaining. Also it looks like one side of the line is longer then the other. I appreciate your help the site is a bugger to search sometimes.You won't be using those at all, I have some close up pictures in my build log in post 70 of how the manual shifter is connected. >>CLICK HERE<< You should have the connectors inside a little goody bag labeled shifter hardware
If I'm not mistaken, DF changed the way they connect the turnbuckle shaft to the shifter. They no longer use the small heim joints and now use the plastic donor attachments.You won't be using those at all, I have some close up pictures in my build log in post 70 of how the manual shifter is connected. >>CLICK HERE<< You should have the connectors inside a little goody bag labeled shifter hardware
This is true you can still get the turn buckles at ACE hardware if your like a knuckle head like me and lose the inner part of the stock one.If I'm not mistaken, DF changed the way they connect the turnbuckle shaft to the shifter. They no longer use the small heim joints and now use the plastic donor attachments.
1/4"-20 I think if my memory is still workingBeen sick all week but I felt decent today so I ended up finishing installing all brake pads and brake lines. Quick question on the hub that the steering wheel sits on with the 3 holes. What size threads are those? I feel like they are M7.100 but none of my bolts I have fit m6 is too small, and m8 too large. I need to order some.
