Thank you! That makes sense.My extra positive near the fuse box was the turbo intercooler pump wire, so its an extra positive there on my supercharged.
The purple wires that get rolled up are extra positives from your fog lights. They originate from the headlight harness block in the fuse box. They will be controlled by the ACC button on the button panel. Can you trace it back or check continuity with the headlight harness purple wires?
Of course I just have a harness in a goblin with no engine yet so maybe someone else can back that all up.
Yes tan B6 goes from fuel pump splice then a long extended wire all the way back on the clutch pedal you will use it in n video 10 as well as the pink wire, the abs brake res wire, the purple passenger fog light and a spare red from BCM connector. Cut all pedal and clutch wires to 12-15" you will have tons of extra wire left on most of stuff its better to have them longer son you can splice within the harness rather than the extended pig tail.I'm a bit behind most others in this thread. I'm towards the end of video 4 about to remove the body to dash connector from the harness.
A couple questions:
1.) I have labelled all the wires and have the "Extension wire - B6" label left over, is this label used later or where do I apply it?
2.) I seem to have 3 remaining, unlabelled wires to the body to dash connector. One of these is a red/white wire that goes to D5 of the small gray multiplug and coming from D3 on the body to dash connector (the accessory plug power wire also shared this pin on the body to dash connector). Does this sound correct? I tend to second guess cutting a power wire, particularly when I don't see it specifically called out in the video. The video shows Lonny cut and remove only 2 wires from this connector, a blue and a green wire.
Thanks.
That red wire comes from the amp radio harness in video 8. I saved every acc wire throughout the build first red comes from fuse box and needs to be spliced after driver headlight.I just completed video 10...
I think it's been going pretty good, but I am left with a couple questions:
@7:17 (step 24 left over positive wire) I don't seem to have a left over positive wire. In the video it looks like it was labeled and I did label everything... Since it's not used should I be worried I can't find it?
Then @ 8:00 (step 27 purple and red wire) I have a purple wire that originates at the fuse box side of the table. It's just barely long enough to get past the EPS mark on the table. Is this probably the right wire? should I extend it?
So how close to the ECM connnector did you cut your wires off! I didn't remove that cover to cut them close I just taped over everything like lonny did and staggered my cut wires to different sizes.I've encountered another small issue / minor mishap.
Around 5:20 of video 4 there is a loose wire to a taped union that is to be cut and removed while cutting out the body to dash connector. I seem to have removed the tan fuel pump wire which I believe was T'd into the B6 (Fuel level) wire. What I think I was supposed to remove is a gray wire that is T'd into B5 (clutch(MU3)) of the body to dash connector. Does this sound correct?
I recall thinking: "I thought I was supposed to keep this wire", *shrugs shoulders and cuts and removes the wire...
I realized this mishap in the 0:10 - 0:20 range of video 6 where 3 fuel pump wires are called out for turbo SS donors, I now only have the purple and gray and the tan is gone.
The junction of the tan wires (the one I cut) was approximately 10" from the body to dash connector. The junction of the gray wires was about 20" from the body to dash connector.So how close to the ECM connnector did you cut your wires off?
Thanks again! I'm on the right track then. Your attachment was very helpful.Those should all be battery positive voltage, which is what you want on that wire to power any extra accessories, so I don't think it really matters. But mine was a thicker wire. Think it went to the amp or stereo. Actually I left both.
