Every time I see a bike with one of those I think if your that scared stay home !The Headlight modulators annoy the hell out of me. You basically just get use to being invisible or be like me and do 99% of your riding on the track.
The intended wire (via DF) is hot at all times when ignition is on. Also, when this is wired up it will actually keep the car running for a couple seconds after switching the ignition off. I don't see a major issue with that, but there's talk of correcting that here on the forum using an inline diode I believe.Does anyone know when the pink wire you put in for the IC pump goes hot? I was thinking about using that to power the fan on my external oil cooler i'll install this week.
Nuker-
The intended wire (via DF) is hot at all times when ignition is on. Also, when this is wired up it will actually keep the car running for a couple seconds after switching the ignition off. I don't see a major issue with that, but there's talk of correcting that here on the forum using an inlineresistordiode I believe.
That sounds good, I actually did a balance shaft delete before I put the new engine in! So good to go there, but I think that is smart to look at that ported head combo because the price is right on it. And if I can make my same power level at a lower boost even better!Your winter mod list looks great! If you're going with the valves / springs / damper you may want to consider the neutral balance shafts as well.
For the valves, if you're thinking about the powell racing $eparator but holding out for an ottp intake manifold (maybe due to costs?) I would allocate the funds for the powell to the TTR intake available now with external pcv and go with a cheap catch can. We're never going to totally escape the valve coking but an external pcv with catch can inline and then maybe meth injection is about the best we can do. I think you have to email powell to purchase btw.
I know you're not interested in cams but ZZP usually has a black friday sale and last year they had a great deal on the ported head, stage 2 cams, 82# valves & retainers and tune. Not necessary for your power goals but might be something to consider!
I'm running 18psi in the front and 20 in the rears, But my camber is pretty high, I'm going to roll the bottom links in a couple threads and see what that gets me on the new tires.What pressures are you running?
Ahhh Yes good idea I'll roll those out like 3 threads and see what happens. I'm going to be out of the country for a while so not sure i'll get to new tires before its cold this year. But next year ohhhh boy.The A arms can be lengthened by the bottom of the A arm (orange), and/or the top (black).
