The EPS contains one of the resistors in the high speed needs to work at it's best. You will need to add a resistor back in if you wire the high speed around the EPS.
"The network can operate with one open resistor, but the signal will be less stable, and communication errors may occur."
https://resources.aeswave.com/ATG-05_Network-Diagnostics-and-Module-Programming.pdf
