I took a little break for a few weeks. Back at it again. I mounted the rear lights with the plates for the side marker lights.
I also got the rear struts on.
A little tip for those running the stock struts. I fought to get the strut up through the supplied aluminum spacer. Here is what I did. I took the tip of the strut and beveled the edge.
I also beveled the edge of the spacer. It made things go together much easier.
And the best part. Got it sitting on it's wheels. The shifter and cables installed and adjusted. I had to trim about a 1/4" from the side to side shifter cable to get it to work correctly.
