Once they have your paperwork tell them you want to get a temp tag. Takes like a week and you get a 40 day temp for about $50. Start driving sooner.So pumped getting closer just did Vin inspection for the Montana route now I mail in and wait 6 to 8 weeks there saying.
That’s the best part of the build process; pissing off the HOA and the Karen‘s.Neighbors watching the FF5R semi pull up, "Well, there goes the neighborhood!" Long sigh....
KAL
I've been putting off the footwell cover and hood install. I had a hinge plan all worked up in my head and then I remembered the ducts. I also wanted to mount them on the inside, but I've finally decided it's going to be a normal install. Now I just need to get it wrapped so I can get the ducts installed.Been searching the forum for info on putting my naca ducts on inside of hood. Seems like putting hood on and off will be a 2 person job while jacked up after adding ducts? Weighing my options putting on the outside should be pretty straightforward but thinking inside would look cleaner
Getting them bled better is also on the list before it hits the street that should help thanksYour calipers are on the wrong side. Bleeder valve goes up.
What did you use to cut them out?Cut it for vents on inside.
