Swift06
Full disclosure, I trimmed my harness before the videos came out and I'm pretty sure I trimmed too much. I was deployed for six months so I'm picking up this project where I left off. I left myself bread crumbs to follow just in case, but I need help.
I have an 05 SS/SC
First, I must have cut the battery current sensor part of the harness, because I don't have the connector. I thought I saved every connector regardless if I needed it, but I guess not. If anyone can tell me which wires on the bcm/giant plugs are for that connector that would be awesome since I'll have to wire one up.
Second, in the assembly videos I just want to make sure I'm wiring the large red power steering wire correctly because the large red plug on the BCM in the video is blocked. It's going from:
here:
http://imgur.com/iYk2qxC
to the bottom left of the red BCM plug in the picture, with the giant red fuse in between, correct?
http://imgur.com/SC4ttzR
Third, what is the light green wire for in the top left of this fuse box plug? I forgot to label it yesterday when I was working.
http://imgur.com/xfmAYh1
Fourth, I trimmed the parking brake switch out, but turns out I needed it. It's a light blue wire that gets extended, but since I cut it back at a junction block or a connector, it would be great to know how long to make it total, as well as which pin the wire comes from.
http://imgur.com/GOBjGIF
I have an 05 SS/SC
here:
