ISO - Corbeau Camlock Lap or Submarine belt
Sluggonaut
Sluggonaut
I managed to lose a lap belt on my Corbeau camlock harness between removing it in the winter and reinstalling it last week. I'm hoping it turns up but I'm trying to source one in the meantime.
I called Corbeau and they said because it is SFI tested as a set, they don't sell individual belts.
If anyone has a lap belt (the one opposite the one with the camlock) or submarine belt off a harness they recently removed/replaced, please let me know.
TIA!
duthehustle93
Does it need to corbeau? I have a few extra sets of harnesses but don’t have any by corbeau. I’d imagine that you can mix/match but did you need a lap belt, or a sub belt? They’re not interchangeable since lap has the adjuster. Also, if you need lap… are yours pull up or pull down?
Sluggonaut
The lap belt is what I am missing, the left side opposite the buckle. It doesn't have to be Corbeau but it needs to be compatible with Corbeau's camlock buckle; otherwise, I'll need an entire harness.
The adjusters are on the outside on the lap belts, so is that pull up?
Pic? My driver seat cam lock messed up (non corbeau) so I bought another in a different brand and the buckle area was identical. You can have whatever belt parts you want from my stash.
Sluggonaut
I need this one:
42320
duthehustle93
let me see if I've got one when I get home.
Pull up/pull down refers to which way you pull the tail to adjust the lap belt. If you pull the tail towards the center of you to tighten, that's pull up.... pull down you pull the tail away from you (towards the shifter/towards the "door") to tighten them.
