V1 Bell housing leak
Stingray
Gents,
I installed a new throw out bearing and new clutch when I first installed the engine. I'm trying to bleed the clutch and brakes and developed a leak I think in the bell housing. It doesn't look like it's dripping from the outside on top. Any ideas what I need to tighten down or replace????? I'm assuming the clutch pipe seal first?? Man I hope I don't have to pull the engine.
Okay, I was able to video the drip. It looks like it's coming from that clutch pipe seal. Going to dealer to pick one up now.
Traé
I just dealt with this piece leaking, there is a small rubber seal that got stuck in my clutch pipe when i pulled it off. Make sure you have this installed.
The top of the nipple missing the seal.
48345
This thread helped me.
I fought a leak here for a while, there just wasn't anything showing as this being the leak point. It would make it down into the bell housing without any sign.
Stretch2126
I’d spray a little brake clean and let it drain if you dumped a lot but if it’s just a little you shouldn’t have to worry about fluid in the clutch.
Is it stuck down in the fitting? mine was pretty in there from trying to press it into place. I read if you want a new seal you have to buy a new assembly.
The T35 pipe with the seal on it is sold separate from the T/O bearing. I have not found the seal sold separately. That would be nice but thankfully the pipe is not very expensive, just pricey enough to be aggravating.
Traé
Yes, if I remember correctly it was 25/35 bones which is not bad! Plus you get a shiny new one every time you misplace the seal :p
