Thank you sir I will call you, thanks for the offer and the help. The harness you guys did seemed perfect when I got it, so I am sure this is something I did after the fact.
Does the read out on the instrument cluster say anything? If not it’s probably data wires assuming your model is similar to the later models. I don’t have the wiring diagrams for your model but I think there are some post on here that say what should connect up.
Maybe a bad connection to power... Loosen the 7mm bolts in the fusebox, and re-torque them down. Can do the same in the BCM. Sounds like a power or ground issue.
The cluster says brake fluid low is all. The anti theft light comes on and then goes away, The info and back buttons worked earlier in the week. It makes me think there is something going on on the BCM.
Group UPDATE:
I noticed a loss fuse in the fuse box. I took the entire box apart and re-squeezed the lead for all the fuse and relays together to make them fit tight. put it all back together and now everything is working!!!!!
