Button Panel Wiring
Looking at the late model schematics that power originated at BCM X4 F9. It did run through the steering clock spring and you may have missed reconnecting there. It really doesn’t matter where you get ignition voltage from though, but it probably should be hot with ignition on.
ATMironov
Thanks Gtstorey, I found that diagram as well, and was thinking the same thing.
@Lonny can you confirm for late model button wiring, the ignition voltage should come from BCM X4 F9?
Thanks!
ATMironov
To close this out, I have confirmed that its powered from X4 F9. I had a blown fuse, #19
K
It looks like I have two gray wires, do I put both of them in with the single gray wire?
NVM I missed step 21 in video 8 about the harness. One of the gray wires gets removed from the harness.
