I have the tan/tan blk stripe coming from EPS connector. But the data wires from the ECM are white/brown. Did I mess up in one of the first videos or not? If not would the wires connect like this. White to tan and brown to tan/black stripe?
From OBDII to the EPS - TN and TN/BK data wires
From the EPS to the BCM - BN and BN/WH data wires
From the BCM you should have TN and TN/BK data wires that will be sent towards the back of your Goblin.
Starting at the ECM
From the ECM you will have a TN and TN/BK data wires which will be sent towards the front of your Goblin
The TN and TN/BK data wires from the ECM will connect to the TN and TN/BK data wires from your BCM.
Thank you sir. Cut the harness open at the ECM and found where I had messed up early on and spliced the white/black twisted pair to the tn/TN and blk and forget to right it down... So while I'm here I'm going to solder in the correct color wires..
