- Ark :D Goblin Guru
Scenario: you have a multimeter, set to read voltage up to 20v max. You have a wire that's supposed to carry 12v. When you touch the positive probe of the multimeter to that wire, and touch the negative probe to ground, you see the expected 12v. But when you add a 12v light bulb to the circuit, you no longer read any voltage at all. What does this mean?
I noticed tonight, my right turn signal does not work now. First thing I did was test the bulb (it's not a bad bulb, it lights when given 12v). The next thing I did was get out my multimeter, and discovered the above scenario. Do I have a short?
