grantcropper
Active Member
- grantcropper Active Member
So,
First off, I'm an idiot. I was working on adding the heat exchanger and the heat exchanger pump, so of course, I had to gain access to the fuse box. To begin I unhooked the positive battery cable from the fuse box and set it aside. All without thinking to disconnect the actual battery. This hot battery cable directly touched the metal housing of the PCM and the car started to click and twitch lights and all and now, it's dead. When I turn the key, the fuel pump turns on as it usually does, but does not turn back of like the normal cycle. Then when I turn the key all the way to turn the engine over, I get nothing. So we checked fuses and there were two blue 15 amp fuses blown associated with the fuel management so we replaced them and the relay (actually, we didn't have relays so we just swapped relays from another spot in the fuse box with the one we thought was blown) and still no fix. We have since purchased a new PCM from ZZP and last night we installed it, crossed our fingers, and still, same results.
What have we missed? Could this be a relay or two blown that we haven't checked?
Here's the saddest part. We are missing the most beautiful weather of the year.
Please help if you have any good ideas, my brothers!
