Emberbronte
- Emberbronte Member
OK guys, I've been lurking a long time and doing a ton of planning and reading, and I finally took the first step towards my kit car, chose DFgoblin and an ECOTEC LEA engine, I wanted the direct injection and E85, and went with the NA 2.4 as I plan on adding a larger turbo later, going for high power. I have the engine and a few extras it came with I will be rebuilding it up to the spec I want and getting it ready before I buy the kit and get the rest of the parts I need over time. will be pulling some from pull-a-part and other buying new as I want special parts, not just OEM ones. any help or suggestions along the way is always appreciated, especially with there not being many performance parts designed for the LEA. right now it's just tear down and clean up to make sure all is in good order then building out the lower end, forged pistons and rods and balance shaft delete.
anyone know how to pull the DI injectors? mine seem to be in there tight. or im missing something.
P.S. I also posted on Imgur if anyone recognizes the pictures.
