V1 New wiring video - coolant wire
ToxicBill
ToxicBill
I was watching the new wiring videos and am on part 4. At the end of that video, it says I should have a pink wire near the fuse box that needs to be extended for the coolant level connector - I don't have that. The coolant level wire is actually green and is connected to the gray/blue BCM connector. The pink wire I cut for the brake reservoir is also connected to the same gray/blue BCM connector.
Have I done something wrong? What an I missing?
The video needs to be changed. The pink wire is for Turbo harnesses only and it is for the Bosche intercooler pump. It originally ran to the EBCM.
