- tim1972 Member
2009, LNF, SS/TC, stock
Replaced crankshaft inserts, piston rings, two new camshafts. Engine started and ran, but only on cylinders 2 and 3. DTC code was P2146 and P2155, indicating injectors 1 and 4 were not functioning. Spark plugs 1 and 4 were firing but were shiny clean, 2 and 3 were black.
After physical wire inspections, resistance testing, and checking grounds and power and finding acceptable integrity of the wiring harnesses, I began to suspect the ECM. Specifically the I/O Low Side Drive Switches, pin #51, 52, 26, and 28 on the X1 side which are related to the injector high voltage control.
Bought a remanufactured ECM from Flagship and after successful security relearn, could not get crank from the ignition switch. However, with the ignition swicth on, and applying B+ power to the connection on the "underhood fuse block" for the 87 crank relay pin, engine would start but run on only cylinders 2 and 3. Cylinders 1 and 4 were still not getting fuel. This ECM was returned.
Bought another used ECM, replaced the modified tune back to stock tune with HP Tuners and engine would crank, but still run on only cylinders 2 and 3. No improvement.
Began to suspect an incorrectly installed timing chain, so replaced the timing chain with a new chain to ensure correct timing.
After reinstallation, I have no crank, no spark, and no instrument panel lights with either of the two remaining ECMs. Applying B+ to the relay crank pin location #87 with the ignition swicth on, I can get crank with both ECMs, but no spark with either.
There is power and ground at the coils.
There is no switched power at any of the pink wires at the BCM. There is B+ power at all the red/white and black/white wires.
Question - There is power at the #30 location for the crank relay, but no power at the #86 location when turning the ignition switch to crank. So no relay activation. Wondering what activates the I/O High Side Drive Switch at the X2 location on the ECM pin #57. It appears that this switch needs to recieve power from somewhere so it can supply power to the Pu/Wh wire that connects to the 86 pin location.
Thought best to identify all this background but hoping to address only one issue at a time to avoid confusion. Hoping to stick to the crank issue to start with.
Appreciate your expert technical assistance.
