Mayor West
- Mayor West Goblin Guru
I am wanting to build a kit without buying things I'm not going to use. Like others have done before, I don't want to use the Air/Water cooling system or possibly the exhaust.
If I don't need the Exhaust, intercooler, heat exchanger, or piping because I'll build my own, do I need to choose the turbo kit? Is the built frame different to accommodate the turbo subframe or anything else? I see the turbo gas tank has a notch built into it, I assume that is still needed even without the water to air kit?
The Turbo kit is +2k and includes.:
Everything stricken out I won't use or could be bought in a separate option without choosing a turbo donor
Those of you who have opted out of the air to water cooling system, how did DF handle the invoicing or did you just eat the cost?
Manual Transmission partsExhaustHeat ExchangerA2W I/CI/C Piping- Turbo Fuel Tank
Rear Brakes
