PARTS? Little bits and stuff found!
No worries. My ignition is not going to fall out and I highly doubt someone is going to say "Hey! Whats wrong with your ignition mounting hardware? Loser!" Lmao
You won’t even see it with the hood on anyways. You could always just trim the bolt shaft down a little?
Comegetjoe. I was in a yard yesterday and the only Cobalt there the column was taken apart. I didn't see any bolts that go in those holes. Maybe go back to goblin tear down video and assembly instructions to see what goes there. I didn't see any hints on parts co's like Rock Auto, sometimes their video's show stuff that is part of the disassembly.
Sorry I’ve been slacking on response! It’s a 2006. The spring is inside the pivot area of the clutch pedal. Basically pushes the clutch pedal “out”. Without it my pedal as a little slop to it
OK!! I'll be looking. I'm getting rained on in Provo just now and I doubt I'll see another decent sized yard until I hit Tucson about 11/12. (Moab is not known for it's junkyards, but ya never know?)
Comegetjoe
[/QUOTE]
I found they are the same on a Malibu. I got you three. I watched a ign switch video and they showed them. I’ll try to get them in the mail on Monday.
MattC Still looking for that spring. No luck in Idaho Falls, Provo, UT or Grand Junction, CO. I'll be in Tucson after Nov 10. I should have better shopping there! 05, 06. 07 maybe? I don't know for sure when the pedal changed but I believe the early style used two switches? Nothing the same at all other than the rubber pedal cover.
In Tucson now. Several Saturn Ions and an HHR manual!? going to try to pull the clutch pedals out of each. I'll post pix of my finds.
Mattc3366
if you can’t find them it’s no biggie! Just this weekend I was able to rig up a generic spring from ace hardware from the clutch pedal to the power steering motor. It seems to be working good
