Brian74 Goblin Guru Brian74 Goblin Guru Dec 28, 2021 #1 Need a top down photo of the right front tire with the steering at full left lock, and another pic with it at full right lock. TIA
Zoom Zoom Goblin Guru Zoom Zoom Goblin Guru Dec 28, 2021 #2 Not the best, If you want more let me know Yes I know my tire is jacked up Attachments image.jpg 316.8 KB · Views: 310 image.jpg 312 KB · Views: 317 image.jpg 318.6 KB · Views: 319 image.jpg 277 KB · Views: 325
Brian74 Goblin Guru Brian74 Goblin Guru Dec 28, 2021 #3 Zoom Zoom said: Not the best, If you want more let me know Yes I know my tire is jacked up Click to expand... That is perfect! Thank you.
ATMironov Well-Known Member ATMironov Well-Known Member Dec 28, 2021 #4 Zoom Zoom said: Not the best, If you want more let me know Yes I know my tire is jacked up Click to expand... How much camber are you running?
Zoom Zoom Goblin Guru Zoom Zoom Goblin Guru Dec 28, 2021 #5 ATMironov said: How much camber are you running? Click to expand... I got it all set now, I just can’t find a new tire until March
Lndshrk Steve Well-Known Member Lndshrk Steve Well-Known Member Dec 28, 2021 #6 That kind of wear comes from a toe problem, not a camber problem.
Lonny Administrator Staff member Lonny Administrator Dec 28, 2021 #7 Lndshrk Steve said: That kind of wear comes from a toe problem, not a camber problem. Click to expand... I agree.
S Scott #321 Well-Known Member S Scott #321 Well-Known Member Dec 28, 2021 #8 Wow I'll bet that had some stability problems with an alignment to cause that kind of wear.
TheNuker Goblin Guru TheNuker Goblin Guru Dec 28, 2021 #9 Scott #321 said: Wow I'll bet that had some stability problems with an alignment to cause that kind of wear. Click to expand... Actually when mine wore like that on my first set (all fixed now) it was rock solid stable up to 5th gear redline LOL Nuker-
