V1 Rear wing recommendations
Mayor West
Finally got around to installing my seibon gt
JPas914
I bought a carbon fiber wing from NRG. 69” wide, but the mounts on the wing are 32” wide and much larger than the DF mounts. I’m trying to find a shop near me to cut and bend the uprights I drew up.
JPas914
Yeah, I didn’t like how small some of the other wings looked on it. IDRVSLO was one of the Goblins that I looked at the get an idea of what size I was looking for.
OptimizePrime
@JPas914 - Check this post, looks like he used spacers (3D printed?). Might be a cheaper alternative to custom uprights.
JPas914
He still had new uprights made, or had to make new uprights. And I’m not really interested in going the route of using 3D printed spacers, nothing against them, it’s not the look I’m going for with these.
PyroGuy923
Does it stick out past the wheels? Can you snap a pic from the back?
JPas914
It’s as wide as the wheels I’m running. Results may vary depending on what you’re running.
When your rear wing gets bigger than your car. o_O:eek: Let's be careful out there Goblineers, don't be one of these guys! :p
Tinkles
I went with a 69" NRG too. I'll be doing new custom mounts too, but I might just bend up the DF mounts to mock it up.
JPas914
Do you have the wing yet? Based off the size of the mounts on mine, just bending the DF mounts probably won’t work. The mounts on my wing are wayyy bigger than the ones included in my kit.
Tinkles
I have had it for a while now. I have the extended chassis, so my main hoop is 2" taller and I want to put the wing up nice and high to get the better air. So I will be needing custom mounts.
If you want to try the DF mounts you could get some 3"ish wide(guessing on the width) flat metal, drill a few holes and then mount that to the wing mounts and mount the DF mounts to the flat stock.
JPas914
I’ve had my wing since the end of May. My work schedule has been hell on my sleep cycle, which is why it’s taken so long to get the mounts made. I had them drawn up and blue-printed 3 days after my wing arrived.
