DCMoney
- DCMoney Goblin Guru
Not you're typical Goblin build for sale. Located in St Peters MO.
$20k
Extremely unique goblin. Custom hood, body panels (cut from .050 hardened aluminum panels), rear wing (nine lives racing element on custom uprights), seat slider brackets, front light bar mount, tail light mounts, line lock rear parking brake. Had cluster reset to zero, 4907 miles on the build, 98k on engine and about 2k less on the transmission. Missouri registered and titled, ready to transfer. Build log is pretty detailed on what went into building this car.
Timing belt/water pump etc less than 5k miles ago
Aftermarket Shifter, (comes with stock shifter)
Dual pass end plate
2.8 pulley installed, 2.9 pulley comes with it.
60lb injectors
phenolic spacer between intake and head
Lightweight ZZP race battery (weights 11lbs).
Sparco R100 Sky seats on sliders for adjustability
GM performance clutch and throw out bearing
ZZP aluminum lightweight flywheel
AEM Air/Fuel Gauge
NGR Quick disconnect steering wheel
Assault Industries leather wrapped steering wheel, not the cheap DF wheel.
Toyo RA1's with less than 700 miles on them
15x7 6UL's front wheel (10.6 lb)
17x8 6UL Rear wheel (~14lb)
Saturn Vue EPS with potentiometer to adjust steering power assistance
Baja Design front light bar as high beam
Rigid industries chase tail lights for brake/turn/back up lights
2 sets of spare body work, not wrapped
Fiberglass engine cover is included but was never used so its bare
Check the drive link for detailed photos, car was just washed prior to pictures so that's water you're seeing under it.
$20k
Dual pass end plate
60lb injectors
AEM Air/Fuel Gauge
Google Drive: Sign-in
Access Google Drive with a Google account (for personal use) or Google Workspace account (for business use).
drive.google.com
