Speed
jirwin
This is definitely not a top speed / back half car because of the aero. Last time I ran the quarter I was making a little over 220hp and I ran it 12.25@107. I'm now making 300hp, but I haven't ran it in a full prepped quarter. No prep 1/8th I did run a low 7 at ~100mph though.
Jirwin is correct, these are not aero friendly cars, so top speed is not its thing, but it’ll definitely get to 100 faster than you can blink.
if I remember correctly, GM says the cobalt has an estimated top speed of 150ish? max rpm x final drive gear ratio x tire size = top speed *if max rpm can actually be achieved in top gear, is a whole other equation.
And don't forget 3300 lbs curb weight for a Cobalt :oops:
Your right I guess a better question would be what's it's 40 or 60 to 100,
Like coming out a corner gunning on a straight how long before I hit top speed
Not sure what to tell you. There’s a lot of factors in that question. Here’s a couple of videos of me on the track. I’m just above stock on hp and although I was running pretty hard, I was still feeling out the car on the track, so I wasn’t at full hammer down.
some accel vids
SmsDetroit
Here is my best on a street in Mexico. According to my draggy. Spinning a bit on the launch.
Wow Justin, you have got your goblin flying! It is an LNF with a ZFR57? Or are you running the ZFR54?
I am building an LSJ with the ZFR57 right now.
J
Thanks, it's an lnf with a zfr7163 and all the zzp goodies. Zzp pistons & rods, zzp ported head and 82lb valve springs, nuetral balance shafts, ati damper and on e85. Makes about 480 on 24 psi
comegetjoe
Between the head and turbo, it just wants to make power higher and higher.
And you're rpm limited... no you're not. Why aren't you spinning higher? you've got the recipe.
J
On the Lnf motor it has cam phasers that i was under the impression you couldn't really go over 7300 with them so that's where I had my tuner set the limiter. Maybe im wrong and it can go higher
I just realized that ZZP offers both a Z57 and a ZFR 7163. Now I am curious which one I have, and what the difference is. The ZFR 7163 is $2270 mentions ceramic ball bearings, the Z57 ($1350) doesn't mention it, so maybe it is cheaper journal bearings? The ZFR also mentions that center housing is actually made from aluminum... is the Z57 center made from cast iron?
comegetjoe
@Ross Z54 pics below are the smaller Z57... definitely NOT aluminum.
Thanks comegetjoe. that helps. I bought the turbo used, off the forum here, and didn't know the difference. Guess I got lucky, as I have the aluminum center housing in a ZFR 7163.
51272
