V1 Stock Seat Troubles
What is the trick to get the stock seats to mount in? I cannot get the front to slide into place.
I’ve been fighting with this for an hour with nothing doing.
Yes, remove the tooth at the front. Also cut 1/4" off the outsides of the rear bolt hole tabs, and remove or trim back the plastic sides to the seat.
I just completely took off the plastic around the base. It kept getting in the way also.
I guess the moto is: when in doubt, grind it out….
Poke up. There is a square hole in the DF frame to accomodate the carrage bolt.
Also the carrage bolt head is less likely to hang up on road debris.
