Hmm, I probably should pull the cover back off to check it out, probably should because of the seal anyways. Might have to do that soon, the last thing I want is to have it jump timing... I have a large flat tip screwdriver that has the reach but was concerned about damaging the chain, covering the end with tape sounds like a good plan. The longest part of the initial installation was resetting the tensioner after trying to install it the first time.
I did rotate the crank with the valve cover off, I put it in 1st gear and rolled the car by hand in the garage but only while I had the zip ties still in place, so only an inch of sprocket rotation. That didn't change the amount of slack that was on the front side off the intake sprocket. I call it slack but I couldn't cause it to skip teeth on the sprocket, I did test that much.
