jFritzies
jFritzies
The time has come to let my goblin go. She’s chassis #288. Donor was a 2008 cobalt LS with 5 speed and 2.2 NA motor. Build started in January 2021 when I picked up my donor and was on the road driving in August 2021. Has been a great car but I just don’t drive it very often and it’s time to put some money into buying my first house.
I’m asking $21,000 for the goblin and a long list of brand new parts I acquired mostly from ZZP the past few years in hopes to build and turbo the motor. After I got a motorcycle I never got around to going through with the upgrades. The parts that come with are listed as follows and would transform this beast to ~350whp.
Has 94,500 miles as it sits. Only put ~1500 on since the build.
Clean title and registration in Oregon
Included parts
  • LSJ TB and gasket-$120
  • Comp Cams boost grind cams-$308
  • Eagle connecting rods-$393
  • Wiseco pistons-$572
  • ZZP Cobalt Turbo kit-$2,095
  • Stage 3 clutch-$1,000
  • Valve springs-$255
  • Neutral balance shafts-$255
  • New timing chain-$103
  • New gaskets and seals-$50
  • .250 throw out bearing spacer-$43
  • ZZP Head bolts-$85
  • ZZP Timing chain guide-$68
  • Rod bearings-$32
  • Ported 2.4 manifold-$210
  • ZZP LE5 to LSJ TB adapter kit-$130
  • Cobalt fuel pump require kit-$29
  • AEM E85 capable fuel pump-$122
  • Fuel injector insulators-$26
  • Stage 1 axles-$200
  • Front and rear main seal-$30
  • Boost reference fuel pressure-$300
  • Larger 3” turbo exhaust from DF-$250
All it would need is a tune from hp tuners after parts install.
Also comes with the upgraded billet shifter kit from DF, wing mount kit, and the button panel set for the gauges.
My number is (541) 217-5085
jFritzies
Some pics of during the build process and of some of the parts included with the car
jFritzies
More pics part two
