Chassis Number 398
Frame Type: Standard Track
Color: Prismatic Powders Custom creation 756, Mystic Purple Base, Chameleon Teal Topcoat
Donor Year / Engine: 2010 / 2.2 XFE Base Coupe
Engine / Trans: 2.2 LAP, ZZP LE5 Cams, Neutral Balance shafts, HHR Big runner intake, 3582r chinaboi, Saturn Vue 4.41 gearset F23 transmission
Wheel Make / Model: Konig Hypergram
Front Wheel - Size / Offset / Bolt Pattern: 17x9 / +45 / 4x100 (57.1x73.1mm Aluminum hub centric rings used)
Rear Wheel - Size / Offset / Bolt Pattern: 17x9 / +45 / 4x100 (57.1x73.1mm Aluminum hub centric rings used)
Spacer Dimension: 4x100 2" thick 57.1mm Hub/Lug Centric
Wheel Weight in lbs.: 38.3lbs
Tire Make / Model: Nitto NT 555 RII
Front Tire Size: 275/40R17
Rear Tire Size: 275/40R17
Seat Make / Model: Corbeau
