V1 Tow Kit Wiring
Does anyone have the schematic for installing the Tow Kit wiring? I saw it somewhere once and now cannot find it searching. I know, I should have bookmarked it when I found it previously. I'm trying to decide between doing this and just getting some magnetic trailer lights that could be used for other things we tow.
Goblinfanclub1234
this thread
On the red BCM plug you will need to tie into the yellow wire (A9) for left brake and turn signal and the Green wire (A12) for right brake and turn signal.
You will also tie into the brown wire at (A7) for the park lamps.
The white wire needs to be grounded.
