jirwin
- jirwin Goblin Guru
You guys think this is ZZP's coil supplier?
LNF/LE5
zzperformance.com
LSJ
zzperformance.com
They look identical. They're either the same, or they use the same Chinese upstream manufacturer.
LNF/LE5
ZZP High Voltage Coil Packs-LNF/LHU/LE5
Market's first ignition coil upgrade for the Ecotec market. Improved core material, more windings, higher voltage. ZZP coils allow larger plug gaps, more horsepower, higher rpm before spark blowout, and better fuel economy. Sold in sets of 4.
zzperformance.com
LSJ
ZZP High Voltage Coil Packs-LSJ
The market's first ignition coil upgrade for the Ecotec market. Improved core material, more windings and higher voltage. ZZP coils allow larger plug gaps, more horsepower, higher rpm before spark blowout, and better fuel economy.
zzperformance.com
