Awesome that makes sense now I have placed an extra wire for the brake and radiator to cover those two for later.Or the ABS system plug. In that case. Those brown and brown with black stripe wires need to be looped to continue its path. Those are the Data wires. I hava a SC too and the defroster wire wasnt long enough for me so i used another wire for the radiator fan.
These are what I have found on it so far, one thread it appears to be the on-star connector if so my donor did not have it. :http://dfkitcar.com/forum/index.php?threads/main-harness-thinning-one-question.1126/Post a picture.
Huge Life Saver ! Wow I need that kind of data in my life. Its a shame cars don't come with this info when you buy them new.I am in the same boat as you right now. My friend that runs a automotive repair shop gave me his log in for all data. Life saver. The defroster wire ended up being a purple wire in the white rectangle fuse block E1 is the location.
Believe that purple wire was actually the power wire for the sunroof if your donor had one.
I too couldn't find my light blue back up wire either and finally said F it and moved on.
Both of those pictures if i am right are of the same plug. Thats the plug that will connect the body harness to the engine harness. Itll be on transmission side of engine harness.These are what I have found on it so far, one thread it appears to be the on-star connector if so my donor did not have it. :http://dfkitcar.com/forum/index.php?threads/main-harness-thinning-one-question.1126/
The other picture is from the opening scene of video series part 12.
Hey. I am building#164 and live in the Short Pump area. (Just West of Richmond for the group) Small world.Hello world ,
I’m joining the fun and building Chassis 162 located in Richmond virginia
I purchased my donor car this past Tuesday locally for 2700 it’s a 2007 ss/sc with a whooping 197k miles on it.
Compression looks decent car still pulls strong. Has a little rattle at startup that goes away after it warms up. Oil is dirty and spark plugs are worn to the nubbins. Clutch looks new !
Where do people sell unused unwanted parts from donors ?
That's awesome ! I'm 20 mins west on 64. Do you plan on driving out to get your frame or have it delivered ?Hey. I am building#164 and live in the Short Pump area. (Just West of Richmond for the group) Small world.
You must be near me. I'm in Twin Hickory, near Deep Run HS. I'm working in Texas, currently. Plan to build it here. I was at their shop a few weeks ago. I have my truck and trailer here. Shoot me a text 804-543-7875.That's awesome ! I'm 20 mins west on 64. Do you plan on driving out to get your frame or have it delivered ?
If you don't have that exact connector don't worry.
I do have that one ! The black,green,grey,redw/black tracer and lite blue got to the top plug on the ecu. I have the light green and blue coiled up and a tan one going to this giant connector.If you don't have that exact connector don't worry.
Yours probably looks like this.
It does connect to the engine harness (not actual location was just checking that it did mate up).
I had to have a indicator on the dash for PA inspection.If you wanted to hook the parking brake wire back up its pin #14 on the BCM plug.
Does anyone know if we have to have this for some reason?
Good to know! That sucks though, Missouri don't care.I had to have a indicator on the dash for PA inspection.
I followed what Chad did from this thread on those wires.Looks like that data wire loops through the big plug maybe abs plug from the ecu and then on to the dash harness that was on the drivers side.
Thought I saw that one before and was looking for it. I cut them from the abs plug and connected them straight to the dash connector from the ecu looks like what chad did in that thread.I followed what Chad did from this thread on those wires.
Help with body harness.
So I have made it to part 10, thinning the body harness, with little or no Hang-Ups. But now it seems I'm at a point where the connectors are not displayed either clear enough or don't match what I have in my harness. Most of the accessories have been discarded already. I know that was a...dfkitcar.com
