Got the new turbo silicones installed and she starts/idles like a champ. Went to end of the block and back, and struggled to get back to the garage.
P-Codes 2101, 0017 and 0300 seem to have cleared up. Probably after finding/replacing the bad camshaft sprocket.
New codes are p0113 Air Intake temp is high and P0036 Heater Oxygen Sensor Control.
My engine coolant ran low since I had replaced the head gasket and drained the coolant off. I topped the overflow tank off and the coolant temp at the dash is showing/staying at 172 degrees. The in/out radiator hoses as well as the coolant tank all feel approx same temp to touch, Hot but not burning my hand.
The overflow tank as well as the coolant hoses in/out of the A2W are warm at best but nothing more.
Oil level is good.
Turbo appears to have excessive heat radiating from the exhaust side. I know the turbos get hot but I felt this was over the top? Pointed shop fan at turbo and exhaust to pull off some heat. I did notice I dropped some sweat on the muffler when bent over looking things over and the sweat sizzled away,,,Seems hotter than it should be??
Guys am I wrong the the amount of heat coming off the turbo or is there something I need to look into????
What are your thoughts on the new codes? These were not showing on the last code reading I published on the forum.
Gonna look to verify engine oil is circulating thru turbo also.
