Looks great, you will probably have to notch the hood, but who cares!I feel it came out pretty good, taller drivers will have an obstructed view, good thing I am only 5’5”!
I like how you tucked that ambient light sensor in the switch panel.Not the easiest way but could provide some inspiration
Those pedals...I know I’m reviving a rather dead thread, but it might be helpful for someone else. I fabricated a mount for mine that mounts just under the gauge cluster. I traced out a template using cardboard to get the mounting point right and make sure it would clear the bottom of the cluster. Then I used some sheet steel from Lowes, some 3/4 inch spacers and 1.25 inch bolts. Once it was all cut out and ground smooth, I gently bent the metal to the angle I was looking for. If it breaks down the road, I’ll redesign it and add some support. I’ll also add a picture from behind the gauge cluster after i get home from work since I don’t have one on my phone.
Love the pedals too... Fill us in please on what those are and how you lengthened the gas pedal. I'm wanting to space out the gas pedal for better heal toeing myself.Those pedals...
I actually didn’t lengthen the gas pedal yet, the angle that the picture was taken makes it look that way. I know that JERMzSS and a few others have done it here....Love the pedals too... Fill us in please on what those are and how you lengthened the gas pedal. I'm wanting to space out the gas pedal for better heal toeing myself.
