The SS/SC is tunable for all years. The non-SS is not tunable for the early years.Arent the 05 ECMs untunable?
Ohhh, I have misunderstood in previous readings. Thank you for correcting me.The SS/SC is tunable for all years. The non-SS is not tunable for the early years.
To further clarify (from my research), the '05-06 2.2 ECU is not tunable. The '06 2.4 (SS/NA) ECU is tunable.The SS/SC is tunable for all years. The non-SS is not tunable for the early years.
I figured needing to scan. I’ll grab that and research more. Thank youCongrats on getting a donor! Vacuum leaks are more noticeable at idle, less at high RPM. Could be a lot of things, a ODBii scan would be a good starting point.
I’m not sure yet. I plan to dig into it this weekend and try to get a list of not stock things that are installed.P0036 is set because you are not using the second O2 sensor.
P0141 relates to P0036 for O2 sensor.
P0442 is set because you are not using the evap system.
P1133 relates to P0036 for O2 sensor.
None of these codes should be causing a stutter in the engine. I would look at fuel pressure, which might not be high enough to keep up with fuel injectors volume required at higher RPM. Do you have bigger injectors?
These codes are 'normal' for a Goblin build. Not certain, but they may able to be turned off - HP Tuners?
I’ll look into that. Not sure about a tune but I planned on getting it tuned anyways to make sure everything is kosher since it has some aftermarket parts and I was told “not tuned correctly”. Has a 2.8” pulley installed and missing a screw :/Late model service manual has p1133 as insufficient switching on sensor 1 so it might be a problem . Need to confirm if it the same for older models.
Upgraded exhaust and K&N intake without a tune could be the problem.
