80% of 12v problems are ground problems. I had the same no crank issue after I painted and reassembled the car and engine assy. It cranked and everything worked during mock up. So it did not take me long to check grounds and fix the issue. I ended up grinding the paint off and welding a ground stud on the angle above the fuel tank. I did not like it bolted up to one of the spare holes in the transmission mount. There is already enough wires in that area.Basically grounds?
Happens often. Electricity doesn't pass through paint and powder coat (especially powder coating). I ground off all the powder coating on the underside of the engine mounts of the frame so metal is touching metal. Also did the same thing with the pedal box and the grounds around it. Very good grounds make for a trouble-free electrical system! Oddly, the donor Cobalts were plagued with poor grounds! Tiffany's car had bad ground and the door locks would work on/off by themselves. I couldn't figure it out until I replaced the engine and found the ground on the transmission to be terrible. After cleaning up all of the ground and swapping out the engine, she never had an issue with the door locks again.
Congrats brother!Thanks for the responses guys! Now i have a few months of custom mods before it hits the road. Exciting!
My ground also seems to travel through the harness to the ground lug (unless I cut it). Did you end up cutting and grounding this wire to the frame? My goblin currently has a no crank condition. I Have not cleaned up the powder coat from the trans/motor mounts yet, that will be next on my list but am curious about what you ended up doing. (my dash lights,fuel pump, throttle pedal and clutch sensor all seem to be functioning)This has me worried, I have a ground on mine but it goes back through the harness to a lug I believe.....I need my engine to get here this week so I can try to get mine started....
Are they all supposed to have that lug coming out of the headlight harness?
Before you clean the powder coat from the mounts, do you have the large ground cable that was originally bolted to the engine/transmission? Use that to ground to the frame. If not, try a jumper cable from the negative of the battery post to block of the engine.My ground also seems to travel through the harness to the ground lug (unless I cut it). Did you end up cutting and grounding this wire to the frame? My goblin currently has a no crank condition. I Have not cleaned up the powder coat from the trans/motor mounts yet, that will be next on my list but am curious about what you ended up doing. (my dash lights,fuel pump, throttle pedal and clutch sensor all seem to be functioning)
Yes I do have the large ground on the trans side I believe I grounded it to the frame already. It seems as though I have extra sets of ground lugs. I have the pedal box grounds, then one that grounds to the floor support bolt. I have an additional set of lugs further back in the tunnel box. Is the normal for the TCs? I have an extension grounding that to the Engine/frame bolt. Now this is just temporary but was hoping to hear it run before finalizing everything. Another piece of info, I can use a jumper wire from the pos + terminal to the starter and it will crank. Thanks for the ideas. I am currently on a long stretch at work but will try to find a sec to check the grounds in the AM.Before you clean the powder coat from the mounts, do you have the large ground cable that was originally bolted to the engine/transmission? Use that to ground to the frame. If not, try a jumper cable from the negative of the battery post to block of the engine.
If you are getting the throttle to move when you first turn the key, the data wires are fine. I can't help to wonder if you just don't have a good ground to the block and therefore the starter has 12v but no ground.
Yes, mine looks a little different if I remember correctly, but yes a connector with a purple wireDo you have the purple wire connected to the starter. Others have forgotten it. This is to engage the relay of the starter.
You said is has 9.6v (which is a very odd voltage). Did you measure that using frame ground or 85 on the relay? Can you tell if that relay even clicks?On the CRNK relay, pin 30 shows 12v. What seems odd is pin 86, the connection from the ECM, shows 9.6v when in both the run and start position.
I'm stumped. The car started and ran fine when I got it. Any ideas?
