Good idea, I have an IR camera.A lazer temperature gun pointed at each exhaust pipe when the engine is running, will tell if you have 1 bad injector, or cylinder.
If you don't have a lazer gun, you can see how long it takes a cold exhaust manifold to get too hot to keep your fingers on.
Great it was a simple fix!Problem solved. I looked at the not working cylinder and saw that the insulator came out and was stuck on the old injector.
It's under the mathHow are you getting injector duty cycle? I’ve only been able to find avg pulse width bank 1.
I don't think so. I think the graph is the actual duty cycle. With the old injectors I was at 125% but only when I was at high rpm and high boost. It was short enough that my wideband sensor never picked up a lean situation.Neat.
So your graph numbers are half values of duty cycle? 31.8 in the graph equals 63.6% duty cycle?
If so...I need to lay off the boost until I get different injectors.
How would I do that?You need to confirm the injector math is correct for a 4 cylinder, unless HPT labeled a for a 4 cylinder. Since it fires 2x more than an 8 cylinder per revolution the duty cycle is double for a 4 cylinder for the same pulse width.
I think that works only IF the 4 cyl is the same displacement as the 8 cyl. Easy mistake.Not sure what I was thinking, but number of Cylinders does not figure into the calculation. Never mind.
