BAR-AIR
Nate has had a lot of hurdles to get this all to work. And it is actually coming out even better then either of us has expected or even dreamed of. As for the logics, the VW community has been converting sand rails and high power custom VW’s to Ecotec engines for years using a similar stand alone set up and yes the ECM needs to be reflashed removing most if not all of the non essentials -no need for the BCM and a new OBDII port is wired right into the new harness. (He has had it only running for a few seconds at this point due to what we think is a throttle body to pedal issue - harness was set up with a Malibu pedal while the plug is the same as a cobalt the internals may be different. As for the lack of key issue, plenty of other ways to secure the ignition and or the car itself whether mechanically or electronically.
