How did that bolt up? DF's mounting kit or through Winglogic's kit?Got a wing for Christmas. Winglogic’s 70 is about the width of the car but it completely changes the look. I ordered rear coilovers as well so now I should be able to get it dialed in a little better.
View attachment 37563View attachment 37564
So winglogic has the foil mounts that you weld underneath it. Then you drill holes through them so you can bolt the wing to the DF mountsHow did that bolt up? DF's mounting kit or through Winglogic's kit?
I like the look of the width of the extra wide wing.So winglogic has the foil mounts that you weld underneath it. Then you drill holes through them so you can bolt the wing to the DF mounts
Is there room to pull the water pump for replacement?A couple weeks ago I started to get a chatter from the engine and I suspect it was the timing chain. I changed both chains tonight with new guides and tensioners. This can be done with the motor in the car if anyone is wondering.
View attachment 37926View attachment 37927
I’ll be able to test it Thursday and pray everything is on right lol. All the marks line up and it seemed pretty straightforward. I also learned that you have to put the new chain on the cam sprockets, then sprockets onto cams.
I’m not fully sure just because the holding tool might be too wide to fit in between the chassis and engine. If it fits I’m sure it would cause the water pump falls out of the other side. But you need the holding tool so the gear doesn’t fall further down the caseIs there room to pull the water pump for replacement?
How crazy can you go with camber on these? I basically destroyed my rears because of uneven wear due to excessive camber (even with camber bolts) on stock cobalt coilovers.Finally got coils for the back. Trying to line up camber took a minute but it’s all back together. I’m running 5 clicks in the front and 8 in the back (soft) but I only drove it for a minute before rain.
I have the fronts around .5 and the back at 1.7. If they wear more than I’d like I’ll try to bring it closer to 1. I had about 1.2 all around before but just changed it so I’ll see how it goes the next week.How crazy can you go with camber on these? I basically destroyed my rears because of uneven wear due to excessive camber (even with camber bolts) on stock cobalt coilovers.
The last time I went to an autocross meet it seemed about right for my tires/ grip level. I could see scrubbing on the side at the top of the little indicator on the tire.Yep. Rear camber is what it is. With stock strut bolts and such, -1.2 to -1.8 seems to be the norm for the rear.
front -.5 to -.8 is great for the street and even track.
